Hey i am using X8 and the camera dont have zoom option moreover my version is 2.1 is there any software for zoom option?
The beauty of the Android OS is that you can still download this (and other) applications on any Android device.
Give it a try.
There is no zoom on this model.
See a post here: http://talk.sonyericsson.com/message/13068#13068 about a recommendation for an app.
i got you but the link u suggested me applies only for xperia mini pro as they are talking about it.....
There is loads of apps on the market which has zoom enabled. However it is a digital zoom and not a analouge one which will cause quality loss on the image.
