Hi guys..
After a long time of being waiting for the release of ICS..
I have noticed that finally my phone SI number had been added to the thread of the SI numbers list.
Okay, That's great!!
BUT, When i checked my phone with PC Companion and SUS..
Both programs are saying that my phone on the latest software 🙂
I have got nothing else to say 😕
this is my suggestion, create a new thread and call it, if you have this SI number or from Egypt please create a ftf file
you can read about how to create a ftf file here
http://talk.sonymobile.com/thread/38251
Sony won't send you the ftf file, but you can go to a sony repair center and ask them to re-install everything
Seems like i'm alone here with my pathetic question !
is your SI number on the list?
Yes, Here is it :
| Live with walkman (WT19) | 1253-5373 | 7/10/2012 |
I would suggest that you uninstall both PCC and SUS > restart your PC > install SUS > restart your PC > then try again
Ok, im gonna do it now and will be back..
*By the way to make sure that everything is going well here..
i have flashed the .58 FW to make sure if things are working or not..
then i tried to connect my phone via usb to get updated to .62 FW ..
And it had been done successfully!
ok that's the reason it's not working, since you already flash a different firmware, PCC and SUS won't update the SI number on the back of your phone, you have a new kit/si number so you can't get your original firmware by using SUS or PCC you need to use flashtool and flash it, but you need to get it, you can create a thread on the XDA forum so someone could upload it
in the mean time you can update to ICS this is how
How to manually update 2011 Xperias to android 4.0.4 build number 4.1.B.0.431
Unfortunately, i tried the ICS Manual update before flashing the .58
But as i'm in egypt.. my firmware should be a little different from the known one ..
like Video unlimited and sony entertainment.. etc
all that bloatware stuff was removed from my original FW..
Also i got a problem after using the generic FTF ..
That google store can't recognize my Carrier!
and when i searched for apps like Whatsapp or Go SMS Pro..
both are saying: This item cannot be installed on your device's country !! :S
_______________________________
i also have searched alot around the internet for my old FW but i got nothing!
i feel like im so stupid to have flashed the ROM manually!!!
Could you help me please with other solution ?
there isn't another solution, just to wait for someone to upload your firmware or check wotanserver
