Contact sony,they will give you better answers than me(hopefully).
http://www.sonymobile.com/global-en/support/contact-us/
There are some compatibility issues between some devices and some headphones.Try newer headphones.Can you insert them correctly in the 3.5 jack?
But is it possible to change something( in the headphones or my mobile) to let them work????:smileygeek:
I do not think they will work.Do they fit correctly in the 3.5 jack?
You are welcome.
