I am from kerala, friends i bought a new xperia mini few days before, when i played fruit ninja in it, i found my phone was missing my finger swipe.
when i surf abt xperia mini i found this happens with the problem of DIGITIZER.
I tried using multi touch paint, still the problem persist.....
Could any one help???
see if its a Software issue (check with SEUS)
i updated it day befor yesterday.........its my warranty period......should i take it back to the shop???
yes, if the problem persists even after you repaired the software you should
will ther b any problem if i over clock my device???
plz help
that could be the reason, remember if you root, unlock the bootloader the phone might act weird or stop working alltogether
repair it again with SEUS
no ....no.... i havnt over clocked yet .......i just wanted to know abt it thats all....will there be any probs if i do so???
your battery life will decrease, and as long as you don't push it to much it should be fine. the best way to find test results on this is the XDA Forum
This seems to be a common problem with the Mini. They have a thread over at XDA that even shows videos of it: http://forum.xda-developers.com/showthread.php?t=1373360 (Xperia Xperia Mini and Mini Pro have the worst touchscreen ever seen!).
