I did a Hard reset for the ray
it kept going for more than an hour, Whatever i do if i shut it down , take battery off all i see is sonyericsson fading in and out
I tried PC repair but it doesn't connect
Help please it's only 3 days old
that's not normal, and why do you restart the phone? do you turn it off at night? you don't have to, just press and hold the power button and select airplane mode instead of shutting down the phone, the issue might be the SIM card, its probably too old
I tried with someone else's name
it worked correctly
Thanks for help and the fast reply
Anytime
