Handy is locked out. SEUS cant help because the handy is locked. Any help?!
SUS should fix the issue, turn off your phone and then repair it with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
