hi,
i have just purchased sony xperia p and i found that during charging my mobile green notification light turn on. but when battery reaches to 100% also the light does not turn off. so how much should i charge my phone becasue the symbol still shows that it is charging. please help.
hi! green light comes on after battery charging reaches 90% and remains until 100%. if this green light does not go off even after you have disconnected the charger then try rebooting your phone. may be rebooting can solve this.:smileyhappy:
hope it helps you:smileyhappy:
thank you for your reply. but i wanted to know after reaching 100% also the green light is on and i did not disconnect the charger.
Hello, as per my knowledge, I think the green light doesn't turn off at all even when the battery gets full. One point you need to know is that the phone is not actually fully charged when it shows 100%. Check if the battery is "Full" in the settings < about phone < status
the green light will not shut off even if the charging has reached its full level i.e 100%. you need to disconnect the charger from the phone.
i also want to tell you that sometimes even after you have disconnected the charger from the phone, and the green light is still on then dont panic, it will go off as you unlock your screen and start using your phone.:smileyhappy:
Yes,and if the green light remains,just turn on phone's screen and the light should stop.
Ok, so the light is orange up to 90%, then green up to 100%, then if I leave it connected on charging the green light stays on continuously but also on the battery status it says Charging, and it can be like that for hours.
Is this what you experience?
