i can't find any gps last two days.it always searching for gps.
Could you please describe your problem in more detail? Which app are you trying to use? Are you located outside? Do you use both Internet and GPS to determine your location?
You should read thread http://talk.sonymobile.com/message/434123 and not ask users always the same questions! Please provide a solution.
i am using polaris navigation.it work's fine on my LWW.i trying also Maps.but still searching.location was set by google when my wifi was on.open sky it found 7 or 8 gps but searching always.location was't set by GPS .my phone is rooted.ICS .75 .BANGLADESH,DHAKA
Remove the SIM card an your phone will find your location. With SIM card no chance - thats t sony! software bugs like this????
why gps not locked????
still waiting!
I flashed the "World" Image to the phone (debrand) and now the GPS works fine! There is a problem with the provider modifications!! Sony should imporve the quality management! It's not the task of the end user.
hi sohel! how are you
Hello,
I'm having the same problem with my xperia P running 6.1.1.B.1.54 build.
Generally it takes 5-10 minutes to lock on GPS satellites; accuracy is 9-15 meters
I tried other xperia P running the same build with identical issue on GPS, this looks to me like general issue.
Can someone responsible reply?
PS:
Restore won’t help, I tried different tools, navigations with same results
Only advice that came up in my mind is downgrade (if possible) to Gingerbread, because with that build I didn’t noticed this issue.
Marek
