hi pros
i've been trying to use the GPS navigation without success.. and google map is, well.. just a map.. it does not tell me my location while im diriving..
im located in south east asia (Malaysia) so anyone know what is a good apps for GPS that will function something like garmin or papago?
i've browsed in android market and some of the apps cost 50USD... wtf???
if you want to use those apps free of cost..
try this..
those will work 100%
try this..
You can try this GPS app.
https://market.android.com/details?id=com.sygic.aura&feature=search_result
It let's you try for 7 days. If you are happy with it, you can decide if you want to purchase the full license
