can i directly connect my xperia p to tv with hdmi and play games or do i need root?
and games will work?
Yes you can connect your phone directly. you can watch movies, listen to music or even play games with it. Try it just connect your phone to your T.V.
thank u
You already got your answer,it is the right one!
