Hello,
A few days ago i updated my Xperia Arc to Android 4.0.4. Now i can't see the pictures and video's that I have on my sd-card in the gallery. They are in the same map as the pictures that i made since I updated my phone. I tried to do settigs > apps -> all > gallery -> clear cache and force stop, then restart, I looked if my album is disabled, it was not. I tried to open the files with astro, that works with the normal gallery, not with the Xperia Gallery, but they still won't appear in the gallery. I also tried to disconnect my sd-card,with no results.
Could someone help me what to do, so I can see me pictures and video's again?
Check if you can clear data for media storage, then check if your media appear again.
Settings > App's > All > Media storage > Clear data.
