hi. i have a problem with my xperia u front camera. i bought it 2 monthes ago and everything worked ok but today i tried to take picture with front camera but when i swiched it from normal to front it stood steel camera started not responting and when i had to force close it. so, from that moment i have same problem when i try to open it. and more, after several force even normal camera dont starts any more. please help.
p.s. my english is exellent :smileygrin:
Try making a repair of the phones software using a computer and the USB-cable and see if that helps. You can find software for that on http://www.sonymobile.com/global-en/support/phones/xperia-u/.
If repairing the phones software doesn't help i recommend that you contact your local Sony Xperia support for assistance with repairs. See http://www.sonymobile.com/global-en/support/contact-us/ for contact details.
First try restarting the phone and see if that helps. If not, does the cameras work from the phones service menu? Open the dialer and dial *#*#7378423#*#* and go to service tests to try the cameras.
camera sometimes works and sometimes don't. I tried it and there is still black screen only. and after several force close even general camera starts not working and then i have to restart phone
