I changed my passowrd and i can't remember what to, i've tried to use pc companion and the other update service, but i keeep on getting and 'insufficent charge' message, and i've heard that there should be a forgotten password button but there isn't one, I've also tried typing in my IMEI code nothing seems to work please help!
Here is Sony update Service
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
you have 2 options
1) keep trying
or
2) reset your phone with SUS, you will lose your sms, mms, call logs and contacts
Bridge (for Mac)
HI If you have forgot the password or pin there should be an option to reset it using Google account username and password that you have registered the phone with. This Needs the phone to be on and connected to the internet for the validation to work.
All your apps and info will still be there on the phone
Steps to unlock
Try to enter the passcode or pattern 3 to 5 times
You will have an option to choose "Next or Retry"
Choose Next and you have 2 options. Secret quiestion if you remember the answer or the google account (Internet required 3G or Wifi connected)
And you have the phone unlocked and you can change the password or pin number
