no you can not
this isn't an iphone
jk at least no you can't do that with Sony's launcher, you can look on the market for other alternatives where you can create folders
Launcher as the homescreen or launcher as the app drawer?
the one with the apps..ok, so its called app drawer.. i mean app drawer.. can i put folder in it?
thanks man.. i already did that but all of them create folders in the home screen only..
now that I think of it, the iphone doesn't have a launcher, the homescreen is the launcher that's why they create folders on the launcher
Yah, but its ok it doesnt mean im gonna get an iphone. haha
good
but if for some reason you want it to look like an icrap
whoah! wait..
how come? im using the google play and the google play app almost everyday..
check this out
https://support.google.com/googleplay/bin/answer.py?hl=en&answer=1067233
