My Phone Sony Xperia XZ F8331... Help me.... My Phone (the software update failed make sure that your phone is connected and try again) HELP MEEE...
29/015/2020 22:15:29 - INFO - <- This level is successfully initialized
29/015/2020 22:15:29 - INFO - JAVA_HOME : c:\flashtool\x10flasher_native\jre
29/015/2020 22:15:30 - INFO - Flashtool 0.9.28.0
29/015/2020 22:15:30 - INFO - Searching for a web proxy
29/015/2020 22:15:30 - INFO - No proxy found, using direct connection
29/015/2020 22:15:30 - INFO - Syncing devices from github
29/015/2020 22:15:31 - INFO - Opening devices repository.
29/015/2020 22:15:31 - INFO - Scanning devices folder for changes.
29/015/2020 22:15:42 - INFO - Changes have been found. Doing a hard reset (removing user modifications).
29/015/2020 22:15:45 - INFO - Quietly closing devices repository.
29/015/2020 22:15:45 - INFO - Devices sync finished.
29/015/2020 22:15:46 - INFO - Loading devices database
29/015/2020 22:15:46 - INFO - Loaded 72 devices
29/015/2020 22:15:46 - INFO - Starting phone detection
29/015/2020 22:15:48 - INFO - Device disconnected
29/016/2020 22:16:18 - INFO - Selected Bundle for Sony Xperia XZ(F8331). FW release : 41.3.A.2.192. Customization : Customized CE1
29/016/2020 22:16:18 - INFO - Preparing files for flashing
29/019/2020 22:19:22 - INFO - Please connect your device into flashmode.
29/019/2020 22:19:37 - INFO - Using Gordon gate drivers version 3.2.0.0
29/019/2020 22:19:37 - INFO - Opening device for R/W
29/019/2020 22:19:38 - INFO - Device ready for R/W.
29/019/2020 22:19:38 - INFO - Reading device information
29/019/2020 22:19:38 - INFO - Phone ready for flashmode operations.
29/019/2020 22:19:38 - INFO - Opening TA partition 2
29/019/2020 22:19:38 - INFO - Current device : F8331 - CB512F1LYB - 1304-9023_R1E - 1302-9157_41.3.A.2.192 - GENERIC_41.3.A.2.192
29/019/2020 22:19:38 - INFO - Closing TA partition
29/019/2020 22:19:38 - INFO - Start Flashing
29/019/2020 22:19:38 - INFO - No loader in the bundle. Searching for one
29/019/2020 22:19:38 - INFO - No matching loader found
29/019/2020 22:19:38 - WARN - No loader found or set manually. Skipping loader
29/019/2020 22:19:38 - INFO - Loader : S1_Root_de8d - Version : 1299-4832_S1_Boot_MSM8996_LA2.0_O_204 / Boot version : 1299-4832_S1_Boot_MSM8996_LA2.0_O_204 / Bootloader status : ROOTABLE
29/019/2020 22:19:38 - INFO - Max packet size set to 4M
29/019/2020 22:19:38 - INFO - USB buffer size set to 512K
29/019/2020 22:19:44 - INFO - Parsing boot delivery
29/019/2020 22:19:44 - INFO - Found a template session. Using it : C:\Users\Sandis Roginskis\.flashTool\firmwares\prepared\41.fsc
29/019/2020 22:19:44 - INFO - Set loader configuration : [00 01 00 00 00 0C]
29/019/2020 22:19:44 - INFO - Opening TA partition 2
29/019/2020 22:19:44 - INFO - Writing TA unit 00002774. Value : 01
29/019/2020 22:19:44 - INFO - Closing TA partition
29/019/2020 22:19:44 - INFO - Processing partition-image.sin
29/019/2020 22:19:44 - INFO - Checking header
29/019/2020 22:19:44 - INFO - Flashing data
29/019/2020 22:19:44 - INFO - Processing cmnlib_S1_Boot_MSM8996_LA2_0_O_204_AID_4_PLATFORM-TONE-COM-LIVE-HWID009470E1-SWID0C-APPID01-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-DE8D-0004-MMC.sin
29/019/2020 22:19:44 - ERROR - Processing of cmnlib_S1_Boot_MSM8996_LA2_0_O_204_AID_4_PLATFORM-TONE-COM-LIVE-HWID009470E1-SWID0C-APPID01-OEM1-AID4-DEBUG00_S1-BOOT-LIVE-DE8D-0004-MMC.sin finished with errors.
29/019/2020 22:19:44 - INFO - Flashing finished.
29/019/2020 22:19:44 - INFO - Please unplug and start your phone
29/019/2020 22:19:44 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings
29/019/2020 22:19:47 - INFO - Device disconnected
and problem Xperia Companion UEUpdateFailed ue_2005
Windows 10 pro 64bit....Help me please FIX
Hello @RoginskisLV
might i suggest to go on XDA forums for your flashtool and flashing troubleshooting.
Firmware tft file dont have bootloader. Try with another tft image, try to download fw with xperifirm
