whenever i post anything from mobile. on facebook i see that only "sent via mobile" . i want to see tht "sent via sony erricson xperia mini pro" .
how to do tht ?
i don;t think we can..
its the application limitation..
how share a post .?
i m having problem with sharing a post that inclusdes text. Facebook for android only share pics & images. why not posts. ?
just like in desktop browser we can see "Share" below each post. But not in Facebook for android. not even Timscape has that option.
well yes , mobile application has limited features , like you cannot upload multiple images , etc etc....
so you just have to live with it....
Can we update "Timescape" application.
Once a time before i used to see sony erricson logo Before Like word on facebook Desktop Layout.
but now when i update through Timscape i see only Via Xperia. Why soo...
my facebook inside xperia not working after ICS update.
it says connection error. but i can log on Facebook app. it runs smmothly.
i even cant add facebook inside xperia account. says connection error try after some time.
this is the error msg i m getting after ICS update.
umm if you notice, you signal is quite weak up there! and EDGE does have uses when on a weak signal, i think thats the problem. try connecting thru WiFi. you might also want to remove the account and then add again, it might solve the problem too.
plus yeah, if you update the status thru Timescape, it says "via Xperia", wayyyy better than "via mobile" :smileygrin:
thanx for reply ayaznoorm
b4 facing this prob . i used timescape on edge n/w . & it run smoothly .
i tried logging in when my signal strenth is strong. but still faced the same error.
i tried removing account & then loging in again , not solved my prob.
i also even factory reset my phone , not solved my prob.
