Dear,
Is it possible to get a notification instantly when someone messages you on the chat function? I have only been able to get one after 30 minutes (closest option)
Thank you in advance,
Willem
Probably a timezone issue?! daylight saving and stuff?! Just my guess ....
Yeah could be, but it should be able to handle that imo
I agree with you on this, but as you know, bugs still exist .... somewhere.
Can I ask you something completely different?
The neo is my first smartphone, in the menu I have 4 screens/tabs for apps, 3 screens were already full during purchase + after the update. If I keep downloading apps, will it create a fifth screen/tab with apps?
The answer is yes.
Try arrange the icons, move it to another new screen.
Will the new screen be created automatically? I can't seem how to move icons, when i touch them the phone just returns to the home menu tabs to place them there
edit: nevermind, figured it out. thank you!
No problem.
