hi
i am using xperia v lt25i
and i couldnt able to flash any ftf files and gettind errors and
shows device disconnected
plz help me anyone
Thanks for the sites and
First thinh i have to do is put win7 or XP to my laptop
and then i ca flash i think
ill keep u posted asap
the problem was with USB port we cannot use USB 3.0 it only supports the USB 2.0
thanks alot for all ua help with those links and paitience
problem solved
thanks t bot (SANJ & THOMMO) thanks alot
glad to hear
Have nice day ahead.
Sanj
