I allowed e-mails to accummulate on my X10 assuming I would be able to remove them en masse. Now it appears the only way is checking each one individually and deleting it. With hundreds, if not thousands, of e-mails this would take me an age. Is there a quicker way?
do it on your computer
the preloaded android email, it's basic, the reason I think google did this is for users to explore the myriad possibilities on the market
try
K9 and Maildroid
Maildroid
K9
if you use timescape, I don't see the point of it but that's another topic
K9 timescape add on
