Experia J: my e-mails just seem to disspear from my inbox, can't find any setting to set limits on time or number of e-mails to archive so why is this happening?
The phone removes emails when they are removed from your email account. If you have a computer connected to this email account, make sure that the email application in your computer (Outlook, Outlook Express etc) is set to leave a copy on the server. With default settings, many email applications removes the emails from the server when you send and receive. The phone will then delete its copies as well.
I hope you can Help, I'm using xperia sp just got it after updating from Miro on which emails were working fine, I could see inbox, upload new emails read and they would all stay in inbox unless I deleted or moved to other file. I'm haveing a few problems with the e-mail on the SP. I can load new msgs read them fine then as I have it on manual load i load new messages the old msg diappear. I can't seem to find them any where, I have checked pop and smtp settings with virginn and entered the correct ones. I can send and recieve ok it's just that they don't seem to stick arround!
please help
