how to active core 2 on xperia v?
as i can see in my battery doctor.. core 1 is working and core 2 is sleeping..
how can i see my items transfered in my microSD from my pc..
by not using settings... is there an app to instantly go to my SDcard files?
I've tested the dual core usage with "cool tool", which could display separate each core. If I stress the cpu both cores are used. It seems, that if one core is enough, the second goes to sleep.
"how can i see my items transfered in my microSD from my pc..
by not using settings... is there an app to instantly go to my SDcard files?"
Could you explaine exactly what's your issue with the sdcard?
no one replies O_O that sucks
thanks for reply..
i need help.. i have my sd card already inserted.. and i already have some files with it... how can i see it?
there is no program so that i can click to view the items in the SD card.... like for example on other phones...
MY FILES ( i can access the items on the SD card
I use this app:
It shows sdcard0 (internal card) and sdcard1 (external SDCard).
would you mind explain to me.. what is the use of ROOTING?
and if its that usefull.. would you try to help me how to do it in my xperia V?
im a new user of andriod device or my phone b4 is really out of date
so i dont have any idea what to do and how to make this device as of much use to its full capacity
thanks in advance for replying to me.. fuck other tech supports there
I've rooted my old mobile (HTC One V). I had to unlock the bootloader and root the device. I installed a recovery (cwm or twrp) and now I could install custom roms, kernels and mods.
The good ist:
- you can change your phone more individually
- you have all rights (root) on your phone to do that.
- you could use custom roms with new features and more speed
- you could overclock the cpu und try undervolting to save battery
- etc.
The bad:
- your factory-warranty is gone (yes you could reset your phone to the factory settings, but if you unlock and root your phone and then brick it and you could not revive it, then you have bad cards related to warranty)
- no OTA-updates; the most custom roms have no OTA-update-support, so you have to reflash to update the custom rom. It's importand to make a backup of your apps, data and settings bevor.
I suggest you to wait until you root your phone. The stock rom is still good. You could later, if the device is not supportet anymore by sony, root it to get new android versions with custom roms.
That's just my opinion
