May I use Ultra MicroSDHC with Xeperia V?
(ie. Toshiba EXCERIA TypeHD Mirco-SDHC UHS-1 Card Class 10)
Yes you can use . I am using SANDISK ultra fro my xperiaV and it working fine.you may check in the sandisk site by choosing the manufacturer and the model of the phone
Gotta, Thank you.^_^
