Sorry for the dumb question, but I just bought the phone, and read somewhere that it comes with a screen protector pre-installed. I looked at the phone and screen and it appears to have one, but I just cannot tell for sure.
Anyone know? or do I have to install the one that came in the box.
Thanks, I have this worked out. I bough an sk17a (the USA model). It has a screen protector pre-installed, you can tell looking for the plastic ridge beside around the earpiece hole at the top of the screen. The plasitic with the red tag is just for protection during shipment and should be removed
it varies from country to country, sometimes they come with 2 so you can install one, sometimes come with an extra one, but for the most part it comes with one pre-installed, check on the outer edge of the screen, take a picture and zoom in so you can see that most likely there is one
Mine come with two, one preinstalled with a red mark on te upper right edge, and a second with instructions to install it.
