Hello
Now i am having my 5th Arc. I have had 3 Arc's and 2 Arc S models and i have had different issues with each one of them.. I just thought that i was unlucky with phones or they didnt like me. Now after the 5th Arc is broken or acting strange i have to write on this forum. The forum have helped me alot when read about problems - but this issues i cant figure out.
The issues relies in the display. When i lock the dispaly so it turns off, of course, then it wont stay turned off. Its black for some seconds, and then it activates the light, without unlocking the phone, just as if you clicked the "homebutton"(Middel button in buttom), and seconds later it turns off again. This This issues presits after software update, restore and re-update. I've been in the store and they testet it and of course as always - When they test stuff there are NO issues or problems at all. So, i hope that you guys will be able to give me some input about what to do or point me in the right direction. Google is my friend, ye, but my friend doesnt understand me when searching the web (Only this issue), so i guess its not that common.
Have to add as well that the "homebutton" have been tested and changed - Its not the button thats loose and keeps making contact.
Hope you can help... Dont wanna buy another one - Got this for 2 months now.
Funny enough, they all end up acting weird after about the same period of time.
Edit 1: Btw, can anyone tell me when Android 4.0 comes as update the phone it self will notifi me. Atm i havent been able to get higher than 2.3 which im using as we speak on my Neo.
I think installing the auto task killer got rid of the problem for me, thnx a lot mate:-)
