I dont know why now my display doesnt switch from vertical to horizontal view, even shaking it.- Only goes horizontal when I slide out the keyboard, or when the camera is loaded.-
Maybe the cause is some misconfiguration or the sensor is faulty ?
Thanks
go to settings > display is Auto rotate on or not?
unrelated topic, if you have some time please check this thread
Thanks uliwooly, that was the problem, the option was uncheked
Regards
Jorge
Anytime
