how to disable vibration feedback while dialling no in live with walkman
its impossible to disable vibration feedback in your phone
even no app can manage to do this
i was just thinking of saving battery by turning off the vibration feedback thankss anyway dude
unless you use a thirdpart dialer from the market
Actually by updating to ICS you get an option in the settings called sound. There you can disable the vibration feature. This feature as stated above is not available in the basic gingerbread software. Hope it helps.
