Kemaren saya mengaktifkan kunci layar dgn mode pola.kemudian saya hendak.menonaktifkan sandi layar.tetapi tidak adalah pilihan non aktif kan sandi layar.semoga ada yg dapat membantu.terima kasih buat yg mau membantu saya.
Yesterday I activated the screen lock with pattern mode. Then I would like to disable the screen password. But it is not the screen password option.
gt
hello @indra_gunsfbgun
the screen password is a backup for when you forgot your pattern or entered it too many times, it is built in android features and unfortunately cannot be removed.
