Hi
I am trying to delete all my contacts from Xperia Mini pro SK17.
I have followed the manuals instructions and from this forum but I am still having a problem.
I have brought up the contacts page and then the delete contacts, settings ect. When I press delete only one contact appears that can be deleted (mark all).
How do I delete all the contacts at the same time.
Thanks
Or you could go trough Menu > Settings > Applications > Manage applications > All > Contacts > Clear data.
Do that for both contact app's and you should not have any contacts left on the phone.
Hi
go to contact app > press menu button> delete contacts > mark all < delete all
see if it works
thanks for the info it is sorted.
