Hi. Please help. I have deleted my pics and screen shots by mistake and need to recover them. Have tried programmes like recuva etc but the drive does not appear in the list.
if your phone its not rooted none of that will work, did you check the thumbnails folder?
there isn't a way to retrieve them, you will have to keep looking for a program that might do it, also connect your phone to your computer > check DCIM > thumbnails, it might not have all the pictures but it will have some not full quality but at least some.
for future reference also back them up with Google
settings > accounts & settings > google > auto upload
also check
google plus > settings > instant upload
you can set it up so it will only upload pictures and videos when you are on a wifi connection
check this thread
http://talk.sonymobile.com/thread/38339?start=0&tstart=0
or use the search bar, you might find an answer
Cant seem to change the mass usb storage either
Yes I checked the thumbnails.No luck.... I am so upset
No my phone is not rooted. Is rooting so dangerous?????
it could be if you don't know what you do, but its not worth the effort, for future reference turn on the auto-backup option with google sync and google plus.
When i open the thumbnails folder there is a file called . thumbdata and a long number. ocupiing 73mb...... cant seem to open it
could i find more pics in there?
Dont care about the quality just need the pics back
on your PC > open folder settings and make sure it show hidden files
