Hi.
1-Is the default music player on SE Live with Walkman made by SE or it's the same in all devices with 2.3?
2-I can't fall asleep with this media player because the player never stops playing music and in the morning you can imagine how the battery his...
Where is the option to turn off repeat?
Thanks
A great alternative is the Music Player made by Google
Google Music (was replaced by Sony Ericsson's music player)
https://market.android.com/details?id=com.google.android.music
it was made by Sony Ericsson, you can not turn off that function
That function always on is just stupid.
While i was waiting for an answer i decided to try powermp and google music. And i prefer google music, despite it's not available for my country. But that´s not a problem...
Thank you
Anytime
you can get the APK here
http://forum.xda-developers.com/showthread.php?t=1350164
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
go to settings -> applications -> check unknown sources
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
You have been a great help.
Thank you again
Anytime
