Hi, I tried upgrading my phone to ICS yesterday, PCC didn´t work at all, so I tried SUS instead. That way it downloaded the latest update but the instalation didn´t work. After that my phone is dead, when I try to start it, I only manage to get to a warning sign and a phone icon in the middle of the screen. And it reboots afterwards. After all this the phone cant connect to PCC any longer, and it still fails when trying to repair and upgrade via SUS. IS it totaly dead now or what should I try?
OK for firmware take this one:
[FIRMWARE][6.0.A.3.73] Central Europe 1 Generic: OT
http://www.mediafire.com/?lej8hf4ii05k67z
http://www.mediafire.com/?kieip5ia3esdk6d
http://www.mediafire.com/?tv110g0jghh2bs4
The link for the swedish firmware has a malfunction!!
Don't unlock your bootloader!!!!!!
I had the same problem with my phone and I'm from germany and it solved our problem!!!
After flashing you could repair your phone with SUS or PCC!
Hey, maas!
Make a hard factory reset: hold the power butten and the volume up button at once for at least 5 sec.till the phone vibrates 3 times.
install on your pc flashtool and the update:http://androxyde.github.com/Flashtool/
then you need to flash an suitable firmware... From which country you are from?
On this page you should find a suitable firmware: http://forum.xda-developers.com/showthread.php?t=1599303
I´m from Sweden, okaj I´ll try that then
Ok I´m trying that firmware. What do you mean with "don´t unlock your bootloader"? And thanks for helping me
Your welcome!
( Not to unlock -->)
Only flash your phone ( in flashmode [turn of the phone und press volume down button and plug the usb cable in at once , the green light of the phone will glow] ) than repair it with SUS in flashmode too!!
Awesome, it looks like it´s starting again :smileygrin: should i try and repair it or use it as it is, or could i try and install ICS again?
Congrats!
Repair it... It should then updated to ICS!
Good Luck!
I've got a few firmwares on my google drive
LT26I_6.0.A.3.75_CE1.ftf
https://docs.google.com/open?id=0B-yM_qnM8ZPRUGV4SlJLbVFVQW8
