Is flashtools the only way to go back to a stock rom if I am currently running a custom rom?
Because I can't update/repair my phone from PCC nor SEUS.
And, if using flashtools is the only option, will it void my warranty?
Thanks in advance,
I wasn't able to find a stock rom for my region (Generic Trade Iberia). There are no available ftf files for Xperia Ray from my region
