Cosmin flow lwp is not working on my neo after i updated to ics .... guys please help....
http://forum.xda-developers.com/showthread.php?t=1725189
got the cosmic flow app for ics ported from xperia s....
update your phone with this..
http://www.sonymobile.com/global-en/tools/update-service
this is an official sony software so don't worry.
and if it says your phone is up-to-date click on install anyway..
this will delete all the phone's data so backup all your files first..
i dont know how sus works .......whenever i open it,it shows resolving network settings--checking for updates---then again resolving network settings----again the cycle goes on.....!!
turn off your firewall and antivurs on your PC
Wait wait,
One version of cosmic flow doesn't works with ICS
install this one
this works but it says 'live wallpaper picker has stopped working',but..it works...then no probs....the older version is not as that as of the new one...but why does nt the sus work on my laptop...?
i does nt work either
Maybe you should try in safe mode
Press F8 at startup and selct safe mode + networking and then use SUS
oh sorry...i just changed the setting to 'silk' for the lwp and set it...again the problem 'cosmic flow has stopped'....
Try to clear it's data
FYI cosmic fliw doesn't works properly in ICS
Maybe developers from xda will import the cosmic flow wallpaper from the ICS of Xperia S
We will have to wait
Try this
