i can't connect to gmail apps. therefore i can't use googletalk and android market. it sucks. can you help?
I suggest performing a Factory Data reset as this should resolve the issue,
Menu > Settings > Privacy > Factory Data Reset ( Note: this will remove data from the handsets memory but will not touch a SIM card or memory stick.)
Hi, for me to help you further, I'll need a bit more info.
Please can you let me know the following?
- How you are unable to connect.
- Any error messages.
- Whether you can access the Internet through the browser.
- Whether you are using 3G or Wi-Fi.
i'm using wifi and the signal is good. however, when i try to connect to gmail therough the app, it says 'can't establish a reliable data connection'. i am able to use the browser though. i could open sites lng facebook and stuff.
It worked. thanks a lot.
