Recently I have changed from using K770i to Cedar. My MH100 handsfree works fine with my old phone, but Cedar cannot detect it. How can I make the it work with my new phone?
The headset must be in "Pairing Mode" for your new phone to detect it.
A) Press and hold the POWER button until the headset turns on, CONTINUE to hold the POWER button until the indicator lights change colours and flash.
OR
B) Turn on the headset. Press and hold the CALL key until the indicator lights change colours and flash.
I believe it's option A that will work, but I can't seem to find my MH100! Regardless, it's a simple problem that is easy to resolve.
OR
Option A does help! THANK YOU! :smileygrin:
