I have no idea,probably some new stuff they want to try out.
Chrome Tabs were moved after Lollipop to the Recent Apps screen (the 2 rectangulars soft button on the right). They will persist even if you restart your phone. You just switched off this feature and can get it back by turning tabs merge on again.
