Good day everyone,
I'm a newbie around here. I just bought myself SE Xperia Arc just today. I would like to inquire if anyone could kindly help me out if I can d/load this type of application or does my phone support it? If there ia any android application website which I could use for chinese language.
Thank you for your guidance & advice in advance...
Cheers!
For info, was tempting you to find out yourself.
Great! You learnt something new today. Remember, curiousity killed the cat (good thing you are not a cat)
Anyway, I guess you have changed it back to English. If not, you should know where to ask. :smileymischief:
i was able to change it back
thanx to se..they give icons besides all the settings
like for language it has an icon Ä
no need for your help
:smileygrin:
My guess was right.
Hope that your curious attitude will help more users.
well i knew you wanted that i should check it myself
yes.....it'll help..
now the battery test results are here ( i asked this long time back..out of curiosity only
gwhispererz,
First of all....Thanks for the info cos it sorted out my problem. I'm very new with this phone.
Did you encounter an error message that made you post the reply multiple times?
I believe you have posted the same reply about 6 times.
slimshaddy,
thanks for the information too... It's been very helpful from U & gwhispererz. So sorry to keep U guys wondering if it answered my question cos I din login here till tdy...
Thanks A Lot...
Cheersz!
apc_user,
Yup....:smileysilly: I managed to delete the other 5 times... I'm a newbie....
Cheersz
No problem .... enjoy your new toy!
gr8
