- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
When trying to change language did I select Chinese by mistake and cannot change it back.
Can anyone please help?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The following message tells you what to do if you have changed the language of the whole phone:
http://talk.sonyericsson.com/message/9489#948
If you just mean for text input, go to where you would notmally enter text and touch and hold the text input area until options appear on screen. One of those is Input method. Tap that and that select the language you want. Standard keyboard or Android keyboard are both English. Other options, on mine at least, are Japanese, Chinese and Korean.
Hope this helps...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hope this helps...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for help it worked
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
but there is only 1 option in my mini x10 which chinese..i want english...how?.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do you mean the language of the phone, or for text input only? if the latter, did you try changing the input method, as I outlined in my earlier message?
Where did you buy the phone? There are regional variations in the software, and it might be (but I don't know) that Chinese is the only option for some regions.
