Hi, there everyone plz do help me I am having problem installing the software of NEO V
When I attach the cable to pc and double click on sony software nothing works. Not even a
Single dialouge box opens up plz do help m everyone I wil b every much thank ful to u
Pc config pentium 4 intel dv8gvsr 10gb ram win xp profsnl
Great thats good u understood... well sir do tell me that also any update of ICS
No na ???
i got that software days before ,, but was in need of a hint "is that right" .ok thnxx ,,
No na ???
lol
ICS has been released in many countries but not globally yet
this is the thread that shows the status
once ICS is released in india , it would be added to the list given in the thread above
Though i am from India as well, but i am running on ICS software
want to know what people feel about it, check these threads below
CHAK De !!!
You are Indian.. Great and a ICS user its great .. But Nexus comes with ICS na..
Or not you are using which phone of sony..
yeah nexus comes with ICS
And i am using Xperia Arc S :smileygrin:
Windows XP contains the drivers you need to take advantage of USB tethering, but you must install a configuration file before connecting your phone to your Windows XP computer, to instruct Windows XP how to configure itself to use those drivers.
You can now use the new Windows XP local area network connection provided by your phone via USB tethering. For more information about configuring networks in Windows XP, see the documentation that comes with Windows.
Its not working..Plzz reply..
make sure your data traffic in enabled ( settings > wireless and net >mobile net > enable data
