I am trying to connect my X10 mini pro tp my pc but it keeps saying it cannot find the phone. It is connected via the USB cable. Do I need to change my settings? No messages come up on the phone at all. Nothing will download or update. Any suggestions?
Excellent
btw here are some methods to backup everything
make sure to mark the useful and correct answers
use the backup & restore app and then
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Success! Updated to 2.1. Turning the phone off and on did the trick.
Settings - Storage gives me 1.8gb free.
great
