Tried using a USB connector and PC Companion, shows "No Phone Connected," I use the "How to Connect" link and see: "PC Companion was Unable to Connect to the Phone..."
Not convenient. Anyone know if this can be solved? I only want to transfer some tunes to my phone via USB, is that asking too much?
you should also check this app
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&feature=search_result
thanks will do
anytime
