hi, i have problems updating my phone to the new system, 6.1.A.0.452. I am using PC Companion and followed the instructions carefully. however, at the 2nd stage (Prepare), my phone will turn off by itself. this is not suppose to happen as i am suppose to switch it off for 5 seconds later. i also have problems connecting to the PC and carrying out the rest of the update process... my phone will be charging instead of being connected to the PC. can anyone help me with this problem? i don't know what to do... i'm stuck at the 2nd stage... thanks!:smileysad:
You have to first switch off your mobile before connecting it
Use the software below to update your phone
Connect your mobile in way shown only when you are asked to
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
________________________________________________________________
or
tried that... same problem... any other options? thanks!
tried that... same issue... any other options? thanks!
try using other pc with SUS/PCC installed
run the program as admin
try using other usb ports
if you can turn your phone on, try a master reset
When you connect your phone in flashmode do you see few drivers being installed on your PC ?
what actually haoppens ?
how do you connect your phone ? and what happens after you connect ?
Moreover it could be due to antivirus and firewalla as well. Try turning them off temorarily until you update your phone ( on PC as well as Phone )
i connect my phone and run the update process. everything will go on smoothly until it reaches the part where i have to unplug my USB cable and phone from the PC. my phone will be in its charging mode... apparently it's already switched off and i can't move on to the next step, which is 'turn off the phone and wait for 5 seconds'. when i connect my phone to the pc, it goes back to charging mode... i cannot update the phone at all...
You are not connecting it in proper way
Please do as follows
i followed the instructions... the computer indicated that my phone was connected... but SUS showed no indication. my phone went into charging mode once again...
