hello there, i have had this xperia x2 for a year and a half now and have been experiencing hangs and that it couldn't be turned off until i remove the battery, my screen wouldn't respond or responds but not on what i have touched and now the worst is that it has been locked and the screen wouldn't respond to its stylus or finger or anything so i can't access it... help please! thanks!
try repairing your phone with
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software20Downloads/Update_Service_Setup-2.11.12.5.exe
thanks uliwooly, i'll try that..:smileyhappy:
if the problem persists most likely is hardware releated
ok thanks, am downloading the update service set up right now...
since i can't unlock my unit, is it okay if i turn it off by simply removing the battery?
yeah, don't do it too often
thanks uliwooly, you've been helpful..:smileyhappy:
Excellent
Don't forget to mark theCorrect Answers & Helpful Answers
