Hey, I can't seem to send texts to only 3 of my contacts since the 2.3 update. Everytime I try one of the numbers, the Messaging Force Closes. I din't understand why it's only 3 of my contacts that do this. Can anyone help?
if you have a lot of sms/mms stored on your phone, the app will start acting up, I would suggest to delete them all, if you want to stored them, sync them to your Gmail, that way you can check them anytime on your phone and/or computer
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
Hi, suggest Factory Data Reset your phone. Goto Settings>Privacy>Factory data reset. This will wipe out phone data completely (SD Card not affected). I believe you should have your backup. Good luck.
anytime, make sure you keep an eye on that, as soon as you notice that your messaging app is lagging check the amount of SMS/MMS you have on it
