My Xperia t2ultra have 5.1 and icon on menu have 2 icon the color is blue if i touch/or lunch aplication not found have Red Micro sd in icon. So i can't delete it why? Help for delete 2 icon in my menu.
This has been answered before. Those apps are not found after a restart or microSD removal because they have been moved to SD card. The solution to remove the blue icons on the home screen is to clear data for xperia home under settings-apps-all.
If you also want to remove the apps, you need to go to Google play and uninstall them from there.
Thread locked.
Thread locked.
