i want to root to downgrade to Android 2.3.7 from ics (Xperia U). i'm going toroot through a sort of app from Bin4y, not using flash tool command, cause i eant to unroot later..
Plus, what will happen if i unlocked it besides the warranty because it's over..
You do not need to root to downgrade - Rooting is mainly for flashing custom roms and installing apps which can remove the non uninstalble pre installed apps
At least some users appreciate it.You are welcome.
Well 1st of all you need a .ftf file which is the firmware file or Stock firmware file, custom roms will have something like .img or .zip
Here is a stock .ftf GB file you may need a plugin to download on some internet browsers
Then follow this guide here - Ignore the title as it's the process you need to follow
Start at step 3 - miss out step 5 then carry on from 6 to the end
Hope it helps
