When i updated my Xperia u my camera not on video on capturing a picture is too slow when i move the phone,also when there is a lamp light,moon light,car light just sayd for any tipe of light on the camera shows tripple of that light if i caputure the moon on the picture are 3-4 moons or the light looks like a black hole.Can you help me ??? what shall i do change the os from 4.0.4 to older one or what because the camera now really (sucks) help please i need my old camera
just leave it charging
connect it to the wallcharger > press and hold the power button and volume up at the same time for 8 seconds and let it charge for 30min then try to turn it back on.
unrelated topic, if you have some time please check this thread
well 36 minutes was charging shall i put it on update now or leave it charging ?
yeah try again
i think the phone now is charging i think i can fix it
ok I'll be here if you need any more help
ok and thanks for helping me i think when everything will be done the camera will be as it was
no problem, you should post some sample pictures indicating which mode are you using and if you use the touchscreen shutter or the camera shutter
http://talk.sonymobile.com/message/244522#244522
i use the both modes and its same
and now i put the phone to be updated and the led bar is green and the sensor for battery near the front camera is red i am waiting to pass in to green then i will update to be sure it will be sucefful
ok just leave it charging for an hour (wall charger) is it a solid red light or blinking?
remember that the camera shutter button has 2 step, press it half way to focus then press it all the way to take a picture
