When i updated my Xperia u my camera not on video on capturing a picture is too slow when i move the phone,also when there is a lamp light,moon light,car light just sayd for any tipe of light on the camera shows tripple of that light if i caputure the moon on the picture are 3-4 moons or the light looks like a black hole.Can you help me ??? what shall i do change the os from 4.0.4 to older one or what because the camera now really (sucks) help please i need my old camera
no no no i didnt disconnected the phone it done it by it self
I don't understand, the phone unplugged itself from your PC? or did the update finished and then you unplugged it? press and hold the power key and volume up for 8 seconds if it doesn't turn on then
connect it to the wallcharger > press and hold the power button and volume up at the same time for 8 seconds and let it charge for 30min
unrelated topic, if you have some time please check this thread
no it only shows sony on the screen and the phone goes of and shows sony again all the time is that
no it didnt unplugged it sayd please check you got battery at least 50% or something and it disconnected during the instalation and it sayd charge the battery before retry
at the first step the phone didnt started and now i plugged in wallcharger and it is the same it starts the sony logo on the screen the the phone turns off and again..again all the time is that is that normal or what shall i do ?
did you try my suggestion?
i dont think the battery is charging how can i check ?
yes i did i followed every step you sayd so like i sayd the phone is in wallcharger and on the display its starting the sony logo and then the phone goes off and again.. and the sensor when the phone is charging up is red and when the phone is charged is green and now its blinking red
any other suggestion ? is there a chance to fix the phone or no ?
