I have the Xperia SP/C5303 running the latest firmware (.205) and it just abouts works perfectly (after a lot of bloatware removal and use of greenify), I've always wondered what the 'Equaliser' setting in the call settings actually does? What does it mean by 'bright' etc..., currently it is normal-the default setting.
Thanks in advance.
Ahh I see, very nicely explained. Thanks!
Hahahaha your welcome and thanks for the compliment
Tnx. It was my question too.
