I have a Sony Xperia ST21a2. For unknown reasons my call log is not updating (not appear incoming/ outgoing numbers). If found this exact problem listed on this forum, tried the suggested fix (Settings - Backup & Reset - Settings Reset), but that is not working for me. Any logical recommendations?
@33956 so you basically reset to factory settings and still nothing? Did you change something in network settings after reset?
As silly as it sounds, I inadvertently fixed it. I can’t tell you how I did, because I didn’t think it would work, so I didn’t write the steps down to communicate it to others with the same problem. Thanks for your response.
Perfect!
